Upgrading to LED headlights on your Silverado dramatically improves night driving visibility. Here’s how to pick the right bulbs.
Silverado Headlight Bulb Sizes:
- Most Silverado models use H11 for low beam and 9005 for high beam
- Some older models use 9006 low / 9005 high — check your owner’s manual
- Silverado 2500/3500 may use different configurations
Why LED Over Halogen?
LED headlight bulbs produce 3-5x more lumens than factory halogens at the same or lower power consumption. The white/blue-white color temperature (5000-6000K) improves contrast for night driving.
Best LED Headlight Options:
1. SYLVANIA 9005 LED Ultra (Best OEM Brand)
The SYLVANIA 9005 LED Ultra from the same brand as factory OEM lighting. Excellent beam pattern, no polarity issues, and maximum lifespan. Sylvania’s backing gives confidence in longevity.
2. Hikari H11/9005 LED Set
Hikari makes bright, well-focused LED bulbs with minimal halation. Strong nighttime beam output.
3. Cougar Motor LED Set
Popular budget brand with solid reviews across most Silverado applications.
Installation:
H11 and 9005 bulbs swap directly:
- Access the headlight from behind (remove the housing or reach through the wheel well)
- Disconnect the factory bulb connector
- Remove the factory bulb (twist and pull)
- Install the LED bulb (check polarity — reverse if light won’t come on)
- Test — both high and low beam
Important: LEDs may cause “hyper-flash” on turn signals. This is not a headlight issue — the LED turn signals have different resistance.
