The gooseneck ball is a critical safety component for heavy hauling. Here’s what you need for a Silverado 3500 Dually setup.
What is a Gooseneck Hitch?
A gooseneck hitch uses a 2-5/16" steel ball that mounts in the bed floor, typically over the rear axle. The gooseneck trailer couples via a wrap-around coupler. Gooseneck can tow significantly more than conventional 5th wheel in some configurations.
Silverado 3500 Gooseneck Ratings:
The Silverado 3500 HD is rated for up to 36,000 lbs gooseneck towing in certain configurations with the Max Tow package. Always verify:
- Your specific build’s towing capacity (from the GM tow guide)
- The GCWR (Gross Combined Weight Rating)
- Hitch weight rating vs. the ball mount weight rating
Best Gooseneck Ball Options:
1. B&W Turnoverball
The B&W Turnoverball is the industry-standard gooseneck setup for GM trucks. The ball folds down flush with the bed when not in use, maintaining full bed access. The frame-mount system provides exceptional stability.
2. Reese 30840
Reese’s under-bed gooseneck hitch system provides a clean install with B&W-equivalent quality at slightly lower cost.
3. Draw-Tite Gooseneck
Draw-Tite (parent company of Reese) makes vehicle-specific gooseneck systems. The Draw-Tite Class IV Hitch for bumper pull is also available from the same company.
Installation Note:
Gooseneck installation requires drilling through the bed floor (professionally done by most dealers and truck equipment shops). The frame mounting brackets must be properly torqued to spec.
