Best Floor Mats for 73-87 C10 – Rubber vs Carpet
Choosing between rubber floor mats and carpet for your 1973–1987 Square Body C10 depends on how you use the truck.
Work Truck vs Show Truck Considerations
If your C10 is a daily driver or work hauler, rubber wins every time. Mud, oil, water, and debris are contained easily and can be hosed out in seconds.
If you’re building a show truck or weekend driver, a period-correct carpet kit transforms the interior and adds a finished, high-quality look.
Best Rubber Mat Options:
Heavy-duty rubber mat material from any auto parts store can be cut to size using the factory floor as a template. Universal fit truck rubber mats from brands like Armor All or similar also work.
For a custom fit without custom cost, FH Group Universal Floor Mats in heavy rubber or vinyl are a good starting point.
Best Carpet Options:
Complete carpet kits from LMC Truck or Classic Industries are the right call for restoration builds. They come pre-cut and include:
  • Driver and passenger floor sections
  • Transmission tunnel cover
  • Seat riser sections
  • Backing and installation instructions
Jute carpet padding underneath makes a huge difference in comfort and noise reduction.
Before Laying New Mats:
Always treat the floor pan metal first. Apply Rust-Oleum 2-in-1 Rust Reformer to any bare or corroded metal, then lay a foam/mass-loaded vinyl barrier before the carpet.
