Best Disc Brake Conversion for Classic C10 – Top Kits Ranked
Drum brakes on a classic C10 are dangerous by modern standards. Upgrading to front disc brakes is one of the best safety mods you can do.
Why Upgrade?
Factory 1947–1972 C10 drums require longer pedal travel, fade under heavy use, and lack the bite of discs. A front disc conversion can cut stopping distance by 20–30%.
Top Conversion Options:
1. Bolt-On Disc Conversion Kits (Spindle-Swap Style)
These kits replace the front drums with a complete disc brake spindle, rotor, and caliper assembly. They typically require a master cylinder upgrade for proper pedal feel. Look for kits specific to your year range (1963–1966, 1967–1972 are different platforms).
2. Wilwood Systems
Wilwood makes premium disc brake kits with billet calipers and drilled/slotted rotors. These are more expensive but are the performance standard for resto-mod builds.
3. Rear Disc Conversion
For a complete disc brake setup, you’ll need a rear conversion as well. This often involves swapping to a 10-bolt or 12-bolt axle housing with disc brake backing plates.
What to Budget:
  • Budget kit: $350–500
  • Mid-range: $600–900
  • Wilwood/premium: $1,200+
Always pair your disc conversion with a dual-circuit master cylinder. The Rust-Oleum 2-in-1 Rust Reform works great for treating any surface rust on the axle housing before the conversion.
