Best Dash Cam for T1XX Silverado – Hardwire vs OBD
A dash cam on your T1XX Silverado is smart protection for insurance claims and documentation. Here are the best options and installation methods.
Why a Dash Cam for Your Truck?
  • Insurance claim documentation (at-fault accident dispute)
  • Hit-and-run parking lot evidence
  • Recording scenic drives
  • Fleet management/teen driver monitoring
Best T1XX Dash Cam Picks:
1. VIOFO A119 Mini 2 (Best Overall)
The VIOFO A119 Mini 2 records in 2K/60fps with STARVIS 2 sensor for excellent night vision. Features:
  • 2K 60fps day recording
  • HDR 30fps for improved dynamic range
  • GPS speed tracking
  • 5GHz Wi-Fi for phone app sync
  • Supercapacitor (safe in hot trucks vs lithium battery)
2. Garmin Dash Cam Mini 2
Ultra-compact, reliable, and integrates with other Garmin devices. Good choice for minimalist setup.
3. BlackVue DR770X
Premium dash cam with front + rear recording, 24H parking mode, and cloud connectivity.
Hardwire vs OBD Power:
Hardwire (Best): Taps into the fuse box for constant 12V power. Enables parking mode when the truck is off. Requires basic electrical work.
OBD Port: Some dash cams use the OBD port for power. Convenient but may drain the battery if the cam doesn’t properly cut off in parking mode.
Installation Note:
The T1XX has a large A-pillar trim for routing the power cable from the camera to the fuse panel, keeping everything hidden. A mini fuse tap and low-profile cable makes the install completely clean.
